لطفا کمکم کنید:
مشکل کار کردن دستور yum دارم
وژن سرور RED-HAT 6.5
و ورژن PYTHON 2.6
نمیدونم باید چیکار کنم
پیغام زیر رو میده :
yum update -y
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
usrlib64python2.6site-packages/pycurl.so: undefined symbol: CRYPTOsetlocking_callback
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.6.6 (r266:84292, Aug 18 2016, 15:13:37)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-17)]
If you cannot solve this problem yourself, please go to
the yum faq at:
http:/yum.baseurl.orgwikiFaq
