سلام من تازه کالی رو روی هارد نصب کردم.
وقتی میخوام آپدیت کنم اول دستور
apt-get update
دستور دوم رو که میزنم
apt-get upgrade
حالا بعد از اینکه دستور دوم رو میزنم بعد از اینکه دانلود میکنه و تا 100درصد میره
این متن برام میاد:
apt-listchanges: News
postgresql-common (200+deb10u1) buster; urgency=high
Existing PostgreSQL databases need to be reindexed
When upgrading from stretch to buster, the glibc locale data is upgraded.
Specifically, this changes how PostgreSQL sorts data in text indexes. To
avoid corruption, such indexes need to be REINDEXed immediately after
upgrading the locales or locales-all packages, before putting back the
database into production.
Suggested command: sudo -u postgres reindexdb --all
Alternatively, upgrade the databases to PostgreSQL 11 using
pg_upgradecluster. (This uses pg_dump by default which will rebuild all
indexes. Using -m upgrade or pg_upgrade is not safe because it preserves
the now-wrong index ordering.)
Refer to the PostgreSQL Wiki for more information:
https://wiki.postgresql.org/wiki/Locale_data_changes
درضمن من نسخه 2018 رو نصب کردم
لطفا راهنمایی کنید
